The Ugly Chair shall not be fully revealed. It’s shy. Its also secretly a recliner. Shhhh… Don’t tell anyone.
It’s also near the front entry, and a convenient place to put boxes as you close the door.
What do you mean by again? Have you owned one before?
Cheers.
Yeah. This is my second.
Technically, third, as one was a gift to a friend that I used for a while. It’s complicated.
Did you get one with an internal card or with the “do nothing” input switch?
No card. Going to run it from the Yggy > Freya S via the balanced outs. Wanted to see what it did for my Empyrean -vs- Asgard 3 / Blackwidow 2.
Please do a comparison between the Asgard 3 and current version of the Jotunheim if you don’t mind. Thank you!!
Do you mean audio wise or just having them placed next to each other on the chair?
Leave Brit Brit alone
thank you Jacob.
The K350 looks promising. I´m tending for a keyboard now(after some research), which follows the mouse between different devices with the “flow” feature. There are 2 or 3 by Logitech supporting it. Like the “Ergo K860”, the “MX Keys Plus” or the “G915 tactile”
That is a neat feature and one I can use myself. I work a lot from home (especially now) and it would be nice to use the keyboard for both my laptop and personal computer.
I have not made that move yet, as I want to be able to split my screen in two as well, for the two computers and I dont want 2 screens.
And that solution I have yet to find.
oh there are a few displays, you can connect multiple sources and switch with the press of a key
this “sharing the display feature” could be achieved with “flow” , if I think about it - at least to some point
This came today - 2 day UPS, took over a week.
Fortunately it opens fairly easily.
Can you guess yet?
Another shot.
And a close up.
Yes - the only pair with blue stators. I’d hoped for purple, the only choice was standard or blue. Waiting on a few more boxes… But you’ve all seen a Bifrost2 unboxing.
Welcome to the Nectar Gang! Damn if I knew I could have gotten blue I would have. Would have matched my amps way better
That’s awesome! Congratulations David.
I’m thinking of getting the ZMF Hybrid Perf pads if I don’t like the pleather. What do you think? Should move this to the Nectar Hive discussion.
Yea I would say move it to the Nectar Thread. Mine are still on the way from Dexs place to mine so won’t get it until this Friday probably. But I am gonna toss on some ZMF Eikon Perf Lambskin at first then try and work from there to see how the sound goes.
